Quartus Prime Lite 25.1 - Issue with the Verilog generate loops
Hi!
I believe, this is the same issue mentioned here, or at least its sibling. Long story short, here is a snippet from the IEEE Std 1364™-2005 standard, page 185:
module addergen1 (co, sum, a, b, ci);
parameter SIZE = 4;
output [SIZE-1:0] sum;
output co;
input [SIZE-1:0] a, b;
input ci;
wire [SIZE :0] c;
wire [SIZE-1:0] t [1:3];
genvar i;
assign c[0] = ci;
// Hierarchical gate instance names are:
// xor gates: bit[0].g1 bit[1].g1 bit[2].g1 bit[3].g1
// bit[0].g2 bit[1].g2 bit[2].g2 bit[3].g2
// and gates: bit[0].g3 bit[1].g3 bit[2].g3 bit[3].g3
// bit[0].g4 bit[1].g4 bit[2].g4 bit[3].g4
// or gates: bit[0].g5 bit[1].g5 bit[2].g5 bit[3].g5
// Generated instances are connected with
// multidimensional nets t[1][3:0] t[2][3:0] t[3][3:0]
// (12 nets total)
for(i=0; i<SIZE; i=i+1) begin:bit
xor g1 ( t[1][i], a[i], b[i]);
xor g2 ( sum[i], t[1][i], c[i]);
and g3 ( t[2][i], a[i], b[i]);
and g4 ( t[3][i], t[1][i], c[i]);
or g5 ( c[i+1], t[2][i], t[3][i]);
end
assign co = c[SIZE];
endmoduleQuartus Prime 25.1std.0 Build 1129 10/21/2025 SC Lite Edition reports the error 10170 when attempting to compile this module:
Error (10170): Verilog HDL syntax error at main.v(22) near text: "for"; expecting "endmodule". Check for and fix any syntax errors that appear immediately before or at the specified keyword. The Intel FPGA Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
Error (10170): Verilog HDL syntax error at main.v(23) near text: ")"; expecting ";". Check for and fix any syntax errors that appear immediately before or at the specified keyword. The Intel FPGA Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
Error (10170): Verilog HDL syntax error at main.v(28) near text: "end"; expecting "endmodule". Check for and fix any syntax errors that appear immediately before or at the specified keyword. The Intel FPGA Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
Error (10112): Ignored design unit "addergen1" at main.v(1) due to previous errors
It accepts it, though, if to embrace the generating loop into "generate/endgenerate" framing.
The Verilog version in the project settings is "Verilog-2001". Changing it to "System Verilog" has no impact on the behavior.
For comparison, I fed this exact snippet to the Questa Altera Starter FPGA Edition-64 2025.2 and it had no problems with it.
So my question is: "What is the root cause of this misbehaving?". Am I understanding the standard wrong? Ot is it some peculiarity of the Quartus itself?
Thanks in advance!
Hi ElShang,
there's a change in generate block specification from Verilog 2001 to 2005. Verilog 2005 states (12.4 Generate constructs, page 181)The keywords generate and endgenerate may be used in a module to define a generate region. A generate
region is a textual span in the module description where generate constructs may appear. Use of generate
regions is optional. There is no semantic difference in the module when a generate region is used.Verilog 2001 requires generate - endgenerate (12.1.3 Generated instantiation, page 169)
All generate instantiations are coded within a module scope and require the keywords generate - endgener
ate.Quartus Prime Std implements only Verilog 2001 and not exactly defined Subset of System Verilog.
In Quartus Prime Pro, the keywords are optional as you expect.
Frank
Hi ElShang,
Frank
