Quartus Prime Lite 25.1 - Issue with the Verilog generate loops
- 1 month ago
Hi ElShang,
there's a change in generate block specification from Verilog 2001 to 2005. Verilog 2005 states (12.4 Generate constructs, page 181)The keywords generate and endgenerate may be used in a module to define a generate region. A generate
region is a textual span in the module description where generate constructs may appear. Use of generate
regions is optional. There is no semantic difference in the module when a generate region is used.Verilog 2001 requires generate - endgenerate (12.1.3 Generated instantiation, page 169)
All generate instantiations are coded within a module scope and require the keywords generate - endgener
ate.Quartus Prime Std implements only Verilog 2001 and not exactly defined Subset of System Verilog.
In Quartus Prime Pro, the keywords are optional as you expect.
Frank
Hi ElShang,
ate.
Frank
Cool, I suspected that would be the case.
Thanks for the explicit confirmation.
