Quartus Prime Lite 24.1 Build 1077 no patches hangs frequently
- 1 year ago
Hmm, I’m still unable to reproduce the issue on my side.
I’ve created a few revisions, but no luck so far.
I’ve attached the modified light.qar file—could you check if you encounter the hanging issue when switching from one revision to another?
Richard Tan
I’ve tried creating a few revisions but haven’t observed any hanging issues—both with the text editor and when opening the Programmer GUI (though I haven’t performed actual programming).
Could you share your project file (.qar) so I can attempt to duplicate the issue on my end?
Also, could you provide the exact steps to reproduce the issue? For example, does Quartus hang for a few minutes or indefinitely when opening a new Text File or Verilog File?
I don’t have a physical board with me—does the hang occur during the programming process, or when the Programmer GUI window is launched?
Richard Tan
- llandis1 year ago
Hi Richard,
Here is a simple qar file. When I switch from one revision to another, it hangs for me. It seems like if I stay within one revision and launch various tools (timing analyzer, chip planner) things are ok. I'm curious if you see the same behavior.
Cheers,
Larry
