Quartus Prime Lite 24.1 Build 1077 no patches hangs frequently
- 1 year ago
Hmm, I’m still unable to reproduce the issue on my side.
I’ve created a few revisions, but no luck so far.
I’ve attached the modified light.qar file—could you check if you encounter the hanging issue when switching from one revision to another?
Richard Tan
Hi Richard
Thanks for the thorough and quick response to my inquiry.
I'm running Windows 11 on a 3 year old PC so i don't think it's the SW/HW setup. I reinstalled 24.1 as admin and retried and see the same issues.
I think its something related to revisions. I am working on this course that uses revisions:
I wrote this course several years ago and used to give it frequently in my apps mgr role. It seems like without revisions everything behaves properly, and I can switch between different Quartus apps without issue. Are their any known issues using revisions that you know about? If you go to the lab manual above you can retrace what I'm doing - it should only take a couple of minutes to create the original design and then make a revision off of it.
Thanks for your help!
Larry
