Nawaf's avatar
Nawaf
2 years ago
Quartus Prime Lite 23.1 PLL Wizard Problem
I am a beginner trying to use ALTPLL to generate a PLL IP. The problem is that the MegaWizard quit when I reach the third step "Output Clocks" and don't allow me to continue the IP generation. First image shows the wizard and the step it quits at. Second image shows the menu that appear after the wizard quit, when "yes" is pressed an empty .qip file get added to the project.
Am I doing something wrong? please help.
  • NazrulNaim_Intel's avatar
    NazrulNaim_Intel
    Sorry for the delay and thank you for reaching out. Allow me some time to look into your issue. I shall come back to you with findings.
    Thank you for your patience.
    Nazrul Naim
    NazrulNaim_Intel
    Sorry for the delay. Can I know which version of Quartus you are using, and which device are being used.
    Nazrul Naim
    • EKaya's avatar
      EKaya
      Having the same issue with EP4CE10E22C8N Quartus Lite 23.1.std.0 build 991.
    NazrulNaim_Intel
    Thank you for the update. I will get back to you as soon as I managed to find the solution.
    Nazrul Naim
  • EKaya's avatar
    EKaya
    Cyclone IV familiy definitely supports ALT PLL, since its introduction in 2009.. Here is a screen shot from Quartus 22.1...
    BTW linked document is dated from 2006, Cyclone IV introduced in 2009... Of course ALTPLL can`t suport it in 2006..
    /****/Solution/****/
    Basic function is broken in version 23.1 ...
    Either downgrading to <=22.1 or copying ALTPLL from 22.1 to 23.x solves the issue...
    Have a nice day.
    NazrulNaim_Intel
    Hello @Nawaf ,
    Do you have the update regarding this issue and may I know what device and Quartus version are you using.
    Looking forward to your reply and to make sure the issue can be solved.
    Nazrul Naim
    NazrulNaim_Intel
    Nazrul Naim
    • Robert_PIN_ASAP's avatar
      Robert_PIN_ASAP
      Hello Intel,
      I installed the patch onto a 23.1 Quartus Lite install, and it fixed the PLL wizard. However, Quartus now repeatedly prompts me to upgrade all the IP blocks even though they are all up to date.
      Please let us know if there is a fix for this and when we can expect a new version of Quartus Lite that doesn't require this patch.
      Thank you.
      • Marco_Intel's avatar
        Marco_Intel
        The patch was for Quartus Standard, not Lite version.
        For Quartus Lite I do recommend to stay in 22.1.
