Quartus Prime Lite 23.1 PLL Wizard Problem
Please note that we released a patch that solves the bug in 23.1 Standard wrt to PLL GUI.
PATCH is available through the following KDB:
https://www.intel.com/content/www/us/en/support/programmable/articles/000098457.html
Best regards
Marco
Hello Intel,
I installed the patch onto a 23.1 Quartus Lite install, and it fixed the PLL wizard. However, Quartus now repeatedly prompts me to upgrade all the IP blocks even though they are all up to date.
Please let us know if there is a fix for this and when we can expect a new version of Quartus Lite that doesn't require this patch.
Thank you.
- Marco_Intel2 years ago
The patch was for Quartus Standard, not Lite version.
For Quartus Lite I do recommend to stay in 22.1.- Robert_PIN_ASAP2 years ago
Thank you for the reply Marco.
The patch in question was posted in reply to "Quartus Prime Lite 23.1 PLL Wizard Problem", and no errors were reported when applying the patch.
Note that I had basically the same problem as reported by Nawaf. When using the PLL IP MegaFunction wizard, the wizard would quit after screen 5 (of 12). Applying the patch fixed the PLL problem, but it also seems to have created at least one new problem (continually prompting me to upgrade all IP blocks).
Most likely we will want to reconfigure the parameters for the PLL using the Wizard. Therefore, we need a stable 23.1 Lite version that supports creating PLLs. Can Intel please create a patch for the Lite version?
we verified installing in Quartus 23.1 Lite the patch released for Standard (later on called 23.1 Lite patched)
It successfully worked and fixed the PLL Issue as you reported.
Starting a new design from scratch in this 23.1 Lite patched, we do not see any issue with other IPs.
We did a test with Nios V /c + Embedded RAM and SPI.In your case, did all IPs or some specific ones are continuously marked to need to be regenerated?
If some specific, can you please let me know which so that I can try to reproduce the issue?
If the issue is the upgrade only, have you tried to regenerate them from scratch instead of trying to upgrade them?
If you can attach the qar of the design I can have a look on my installation.
(if you can't no problem I can try to reproduce with the info asked above)
Marco
