Gab3
2 years agoQuartus Prime Lite 19.1 Error Message when doing run simulation for Waveform
Hello, I am trying to put a project together and when I design my logic circuit and compile, it is successful. When I create a University WVF file, and try to do run simulation it give me an error t...
TingJiangT_Intel
Contributor
2 years agoI've found a solution. When you click "Run Functional Simulation" again, a window will prompt you to save the .vwf simulation file. Please use the default path and file name (do not modify it yourself) during the saving process, and this should resolve the error.
Gab3
2 years agoHello,
Today, my waveform simulation worked. I don't know what I did different but here are some screenshots attached.
