Quartus Prime 22.1 encounter error when establish DDR2 IP
I have tried to generate the ddr2 example design at my end but I don't encounter similar issue during the generating process.
What is the OS version and build that you are currently using?
Can you try to generate the design in shorter path name?
Can you check if you are able to generate the design in Quartus lite edition?
Adzim
My computer operating system is window11, this time I use quartus prime lite 22.1
The path length should be quite short.
When using the lite version, the following screen will be stuck when generating the sample file. It seems that it cannot be finished.
