Dragon666
2 years agoQuartus Prime 22.1 encounter error when establish DDR2 IP
Quartus Version : (Quartus Prime 22.1std) Standard Edition FPGA model: Cyclone IV E (EP4CE55F23C8) When establishing DDR2 IP, the following error occurs. Please tell me how to effectively solve thi...
AdzimZM_Altera
2 years agoHello,
Thank you for submitting your question in Intel Community.
I'm Adzim, will assist you in this thread.
Are you able to generate the IP only?
Can you generate the example design through the tcl script?
Is there any example design that has been successfully generated from same machine?
Adzim
Dragon666
2 years agoAre you able to generate the IP only?
Unfortunately, I cannot successfully use Quartus 22.1 to generate DDR2 IP. When I generated the IP, I encountered the above error, but I currently don’t know what the error means.
