Amir3's avatar
Amir3
4 years ago
'quartus_pgm' command - works with "Nios II Command Shell" but not with batch file
Hey everyone,
I'm trying to burn Flash memory device (MT25QL256) with SW image (Nios Application) by Batch file with these commands, and always I get an error:
C:\intelFPGA_lite\18.0\quartus\bin64\quartus_pgm --nios2 --epcq --base=0xY --csr=0xZ --cable="USB-Blaster [USB-2]" X.flash
This Batch file located in the same path of "X.flash" file.
When I'm trying to burn Flash memory device with "Nios II Command Shell 18.0" tool with these commands, It's work:
1. cd Path
2. quartus_pgm --nios2 --epcq --base=0xY --csr=0xZ --cable="USB-Blaster [USB-2]" X.flash
The 'quartus_pgm' command is the same in both scenarios, so I don't understand why it doesn't work with the Batch file.
Note - Path, X, Y and Z have no special meaning, I can't write down the original data.
Thenks.
