Amir3
4 years ago'quartus_pgm' command - works with "Nios II Command Shell" but not with batch file
Hey everyone,
I'm trying to burn Flash memory device (MT25QL256) with SW image (Nios Application) by Batch file with these commands, and always I get an error:
C:\intelFPGA_lite\18.0\quartus\bin...
KellyJialin_Goh
3 years agoHi,
Could you share your .bat file for reference?
You can also adjust the path:
C:\intelFPGA_lite\18.0\quartus\bin64\quartus_pgm --nios2 --epcq --base=0xY --csr=0xZ --cable="USB-Blaster [USB-2]" <path to X.flash file>.flash
Thank you.
Kelly
Amir3
3 years agoHey Kelly,
The Batch file:
C:\intelFPGA_lite\18.0\quartus\bin64\quartus_pgm --nios2 --epcq --base=0xY --csr=0xZ --cable="USB-Blaster [USB-2]" X.flash
pause
Remminde you the Batch file stores in the same Path as the other relevant files (X.flash and more).
