Amir3
4 years ago'quartus_pgm' command - works with "Nios II Command Shell" but not with batch file
Hey everyone,
I'm trying to burn Flash memory device (MT25QL256) with SW image (Nios Application) by Batch file with these commands, and always I get an error:
C:\intelFPGA_lite\18.0\quartus\bin...
KellyJialin_Goh
3 years agoHi,
Is the X.Flash in the path of C:\intelFPGA_lite\18.0\quartus\bin64\quartus_pgm?
Are they in the same directory with the quartus_pgm executable? If no, could you copy the X.flash in the same directory as the quartus_pgm.
Thank you.
Kelly
- Amir33 years ago
Hey Kelly,
The Batch file in the same directory of the X.flash, for example:
- Flash file directory - Path/X.flash.
- Batch file directory - Path/Burn.bat.
Do you want me to move the Flash file and Batch file to the path of quartus_pgm application? (C:\intelFPGA_lite\18.0\quartus\bin64\quartus_pgm)
