quartus_pfg --info .pof Fatal Error
Hi there,
Is this POF directly converted from a SOF? Does it include any additional binary files, such as a .hex file for the HPS or others?
Typically, a POF is not suitable for use with the quartus_pfg --info command. However, if the original SOF is trusted, the POF generated using the PFG tool is usually not problematic.
WZ
If the POF is not suitable for use with the quartus_pfg --info command, can you suggest another way to verify the bitstream is encrypted?
The files are created using the OFS build_flash.sh script, while ofs_top_pof_flash.pfg was modified to enable encryption.
Specifically, The pof is created with "quartus_pfg -c ofs_top_pof_flash.pfg".
This is the content of ofs_top_pof_flash.pfg:
<pfg version="1">
<settings custom_db_dir="./" mode="AVSTX8"/>
<output_files>
<output_file name="ofs_top" directory="output_files/" type="POF">
<file_options/>
<secondary_file type="MAP" name="ofs_top_pof">
<file_options/>
</secondary_file>
<flash_device_id>Flash_Device_1</flash_device_id>
</output_file>
</output_files>
<bitstreams>
<bitstream id="Bitstream_1">
<path signing="ON" finalize_encryption="1" qek_file="keys/aes_root.qek" password="keys/passphrase.txt" signing_pem_file="keys/ac_adp_dev_fim_root_private_384.pem">output_files/ofs_top.sof</path>
</bitstream>
</bitstreams>
<raw_files>
<raw_file type="HEX" id="Info_Factory_1">./factory_image_info.hex</raw_file>
<raw_file type="HEX" id="Info_User_1">./user1_image_info.hex</raw_file>
<raw_file type="HEX" id="Info_User_2">./user2_image_info.hex</raw_file>
<raw_file type="RBF" id="VAB_Option_Bits_File">./vab_option_bits.bin</raw_file>
</raw_files>
<flash_devices>
<flash_device type="CFI_2Gb" id="Flash_Device_1">
<partition reserved="1" fixed_s_addr="0" s_addr="auto" e_addr="auto" fixed_e_addr="0" id="OPTIONS" size="0"/>
<partition reserved="0" fixed_s_addr="0" s_addr="0x00010000" e_addr="auto" fixed_e_addr="0" id="Option_Bits_VAB" size="0"/>
<partition reserved="0" fixed_s_addr="0" s_addr="0x00020000" e_addr="auto" fixed_e_addr="0" id="Factory_Image" size="0"/>
<partition reserved="0" fixed_s_addr="0" s_addr="0x04000000" e_addr="auto" fixed_e_addr="0" id="User_Image_1" size="0"/>
<partition reserved="0" fixed_s_addr="0" s_addr="0x07FF6000" e_addr="auto" fixed_e_addr="0" id="factory_image_info" size="0"/>
<partition reserved="0" fixed_s_addr="0" s_addr="0x07FF7000" e_addr="auto" fixed_e_addr="0" id="user1_image_info" size="0"/>
<partition reserved="0" fixed_s_addr="0" s_addr="0x07FF8000" e_addr="auto" fixed_e_addr="0" id="user2_image_info" size="0"/>
<partition reserved="0" fixed_s_addr="0" s_addr="0x08000000" e_addr="auto" fixed_e_addr="0" id="User_Image_2" size="0"/>
</flash_device>
</flash_devices>
<assignments>
<assignment page="1" partition_id="User_Image_1">
<bitstream_id>Bitstream_1</bitstream_id>
</assignment>
<assignment page="2" partition_id="User_Image_2">
</assignment>
<assignment page="0" partition_id="Factory_Image">
</assignment>
<assignment partition_id="factory_image_info">
<raw_file_id>Info_Factory_1</raw_file_id>
</assignment>
<assignment partition_id="user1_image_info">
<raw_file_id>Info_User_1</raw_file_id>
</assignment>
<assignment partition_id="user2_image_info">
<raw_file_id>Info_User_2</raw_file_id>
</assignment>
<assignment partition_id="Option_Bits_VAB">
<raw_file_id>VAB_Option_Bits_File</raw_file_id>
</assignment>
</assignments>
</pfg>
