quartus Launch simulation library compiler cant find the questa executable
Sometime, it is because of the mismatch version of the Quartus and Questasim. May I know what version that you were using for both? Can you use the latest version?
If you were to test out this example design https://www.intel.com/content/www/us/en/docs/programmable/683248/18-0/open-the-example-design.html
Will you see the same problem? The reason for the ask is to narrow down to see if this is due to environment problem or not.
- agemoz1 year ago
Hello KennyTan,
Thank you for your reply. I downloaded the latest quartus and questa shown on the Intel/quartus linux download webpage.
I show quartus as version 24.1std.0 Build 1077 03/04/2025 SC Lite Edition. When I run questa from within Quartus, I see this:
Siemens Questa Intel Starter FPGA Edition-64 2024.3
Revision 2024.09 Date Sep 10 2024
Some other issues I am running into. If you could help me with these as well, I would appreciate it. Should I file separate tickets for these?
I do have a valid permanent quartus license for the full version of quartus, but I haven't figured out how to get this software to take that license file.
I am also continuing to support an Arria IIGX project, which this version of Quartus doesn't support, so I still run the old Quartus II 13.1 on another machine, since the two versions of Quartus appear to conflict with each other.
I will try your example download shortly.
Robert Morrison
- agemoz1 year ago
Hello KennyTan,
The example design compiles file, but running the simulator generates the same error, it now cant find the cyclone 5 simulation libraries:
# ** Error (suppressible): (vopt-19) Failed to access library 'cyclonev_pcie_hip_ver' at "cyclonev_pcie_hip_ver".
# No such file or directory. (errno = ENOENT)Robert Morrison
