12 years agoQuartus II web edition crashes during synthesis of tutorial project files
Hi Everyone,
When I try to run Analysis and Synthesis of the tutorial projects (both the pipemult and the fir) Quartus II 13.1 web edition crashes. I deleted the db folders in the project file as suggested in a discussion but it still crashed the same way. Ideas?*** Fatal Error: Access Violation at 0X000000007505C5C6
Module: quartus_map.exe
Stack Trace:
0x6c5c5: std::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> >::substr + 0x13a5
0x689a9: DGAPI_GetPlugInContext + 0xb929
0x3d7af: std::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> >::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> > + 0x5abf
0x3f9c6: std::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> >::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> > + 0x1126
0x3fe26: std::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> >::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> > + 0x1586
0x4029e: std::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> >::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> > + 0x19fe
0x42090: std::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> >::basic_string<wchar_t,std::char_traits<wchar_t>,std::allocator<wchar_t> > + 0x37f0
0x25d91: rename + 0x9
0x4b2d: PDB_BASE_SEGMENT::xfr_c_str + 0x97d
0x52d8: pdb_write_ptr + 0x138
0xd648: PTI_DB_MANAGER::get_instance + 0x24c8
0xa0af: PTI_MANAGER::get_total_unateness + 0x3cf
0x93caa: PTI_EXPORT_UTIL::get_io_current_strength + 0x17ca
0x93ef4: PTI_EXPORT_UTIL::get_io_current_strength + 0x1a14
0x243a0: LdrShutdownProcess + 0x1d0
0x241af: RtlExitUserProcess + 0x8f
0x20ccc: _get_pgmptr + 0x248
0x1652c: BaseThreadInitThunk + 0xc
0x2c540: RtlUserThreadStart + 0x20
End-trace
Quartus II 64-Bit Version 13.1.0 Build 162 10/23/2013 SJ Web Edition
