18 years ago
Quartus II mux for schematic entry?
Sorry for the newbie question:
I have Quartus II 4.2 Web edition.
I don't see a multiplexer symbol in the Quartus library, unless I open the Max II folder. Ok to use the Max II 74 series libraries?
JohnP
    Hmm. No design files for MaxPlus logic cells.
    Guess I have to make a mux from AND and OR gates?
    Clancy:
    I placed "BUSMUX" into my desgn. I set the "width" parameter to 8, then double clicked on the mux icon, error message says:
    Can't locate design file for entry "BUSMUX"
    Use lpm_mux.
    Make sure you have "Launch MegaWizard Plug-In" check box selected.
    Press OK.
    Select your HDL language (it will autogenerate a wrapper in the language you select).
    Press Next and enter the mux parameters. Continue to Finish.
    I hope this helps :)
    Always use lpm_ library components if available.
