18 years agoUse lpm_mux.
Make sure you have "Launch MegaWizard Plug-In" check box selected. Press OK. Select your HDL language (it will autogenerate a wrapper in the language you select). Press Next and enter the mux parameters. Continue to Finish. I hope this helps :) Always use lpm_ library components if available.
