14 years agoQuartus II internal Error
Hi all,
I am making compilation for my RTL design. At first I used Quartus II 10.0 (32-bit) (Analysis & synthesis are OK) The process stopped at Fitter (Place & Rount) with an ERROR "Out of memory in module quartus_fit.exe" I was told maybe it will be fixed if I use Quartus II 10.0 (64-bit) But when I retry it using Quartus II 10.0 (64-bit), (Analysis & synthesis are OK) some internal error occur at Fitter (Place & Rount) Following is the log in a pop-up window, *** Fatal Error: Access Violation at 0X000000003E8B34EB Module: quartus_fit.exe Processors in use: 2 Lock in use: 9 Stack Trace: 0x332897: VPR_QI_FACADE::vpr_qi_main + 0x177 (fitter_vpr20kmain) 0x30890: fitapi_run_vpr + 0x70 (fitter_fitapi) 0x40c2f: FITCC_EXPERT::run_vpr + 0x15f (FITTER_FITCC) 0x421d4: FITCC_EXPERT::place_and_route + 0x174 (FITTER_FITCC) 0x438b9: FITCC_EXPERT::invoke_fitter + 0x759 (FITTER_FITCC) 0x2385: ftitan_execute + 0x265 (fitter_ftitan) 0xb17d: fmain_start + 0x7cd (FITTER_FMAIN) 0xfd5b: qexe_get_tcl_sub_option + 0xefb (comp_qexe) 0x133f5: qexe_process_cmdline_arguments + 0x605 (comp_qexe) 0x13521: qexe_standard_main + 0xa1 (comp_qexe) 0x1a88: msg_exe_fini + 0xf8 (CCL_MSG) 0x1a2c: msg_exe_fini + 0x9c (CCL_MSG) 0xa2b0: operator new[] + 0x130 (ccl_mem) 0x35ff4: msg_exe_main + 0x74 (CCL_MSG) 0x1f56c: BaseThreadInitThunk + 0xc (kernel32) 0x33280: RtlUserThreadStart + 0x20 (ntdll) End-trace Is there anybody can help me ? Any suggestion is welcome. Thanks a lot. Best Regards Evander
