--- Quote Start ---
The RAM for 32-bit OS is 4G (3.24G usable)
You mean it's still not big enough for EP3SL340 ?
But as I know, the max RAM size support by 32bit OS is 3.24G.
The RAM for 64-bit OS is 4G which is less than 6.0G as you said.
So the root cause of the internal error in quartus 64-bit is still the less of RAM ?
I feel dizzy why didn't it show "out of memory" just like situation in quartus 32-bit ?
Thank you very much.
Evander
--- Quote End ---
unfortunately it is diffcult to say what the root cause for internal error of the 64bit version is. Can you try Quartus version 11.0 or 9.1 ?
After "Analysis & synthesis " you could see the device utilization. If possible try a run with a smaller target device ( with less memory requirement). If the run finished succesfully we can be sure that the problem is not design related.
Kind regards
GPK
