--- Quote Start ---
Hi all,
I am making compilation for my RTL design.
At first I used Quartus II 10.0 (32-bit)
(Analysis & synthesis are OK)
The process stopped at Fitter (Place & Rount) with an ERROR "Out of memory in module quartus_fit.exe"
I was told maybe it will be fixed if I use Quartus II 10.0 (64-bit)
But when I retry it using Quartus II 10.0 (64-bit),
some internal error occur at Fitter (Place & Rount)
Following is the log in a pop-up window,
*** Fatal Error: Access Violation at 0X000000003E8B34EB
Module: quartus_fit.exe
Processors in use: 2
Lock in use: 9
Stack Trace:
0x332897: VPR_QI_FACADE::vpr_qi_main + 0x177 (fitter_vpr20kmain)
0x30890: fitapi_run_vpr + 0x70 (fitter_fitapi)
0x40c2f: FITCC_EXPERT::run_vpr + 0x15f (FITTER_FITCC)
0x421d4: FITCC_EXPERT::place_and_route + 0x174 (FITTER_FITCC)
0x438b9: FITCC_EXPERT::invoke_fitter + 0x759 (FITTER_FITCC)
0x2385: ftitan_execute + 0x265 (fitter_ftitan)
0xb17d: fmain_start + 0x7cd (FITTER_FMAIN)
0xfd5b: qexe_get_tcl_sub_option + 0xefb (comp_qexe)
0x133f5: qexe_process_cmdline_arguments + 0x605 (comp_qexe)
0x13521: qexe_standard_main + 0xa1 (comp_qexe)
0x1a88: msg_exe_fini + 0xf8 (CCL_MSG)
0x1a2c: msg_exe_fini + 0x9c (CCL_MSG)
0xa2b0: operator new[] + 0x130 (ccl_mem)
0x35ff4: msg_exe_main + 0x74 (CCL_MSG)
0x1f56c: BaseThreadInitThunk + 0xc (kernel32)
0x33280: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Is there anybody can help me ?
Any suggestion is welcome.
Thanks a lot.
Best Regards
Evander
--- Quote End ---
which OS are you using and what is your target device ?
Kind regards
GPK
