11 years ago
Quartus II Internal Error on finishing fitting
Hi All,
I've posted about internal errors before, but now I am getting a different one. The code was compiling without issue until I changed an "if" condition to use a different register within the module, and now the code won't compile and generates the following error at 92% of the way through fitting. If anyone has any knowledge as to why this might be please let me know. Is re-installing the Quartus II software my only option, or is there something specific my code may be doing that could cause this? (Code snippet is also below)
Thanks for any help!
Variable definition (the first in input from a different module, the second is an output from a FIFO constructed within the module);
input FIFO_Read_Rq;
wire FIRFIFO_Rd_Empty;
Culpable IF statement (the first condition compiles fine, the second - shown here active, does not compile at all;
if(/*FIFO_Read_Rq == 1'b1 && */FIRFIFO_Rd_Empty == 1'b0)
begin
Out_Data[15:0] = PD_Data[15:0];
end
Internal Error Message;
Internal Error: Sub-system: HDB, File: /quartus/h/qtl_object_cache_sys.h, Line: 711
slice->m_locks == 0
Stack Trace:
0x959a0: HDB_ENUM_OPTION::get_value + 0x282a0
0x47e96: HDB_ACTION_PT_INSTANCE::find_design_unit + 0x4f6
0x2117: HDB_FILE_DEPENDENCIES::~HDB_FILE_DEPENDENCIES + 0x1d7
0x1fa3: HDB_FILE_DEPENDENCIES::~HDB_FILE_DEPENDENCIES + 0x63
0x40bb0: HDB_ACTION_PT_INSTANCE::~HDB_ACTION_PT_INSTANCE + 0x250
0x57a5c: HDB_CHIP::reset_visited_flag + 0x33c
0x5db48: HDB_CMP_ACTION_PT_INSTANCE::sweep_timegroups + 0xe8
0x5db6d: HDB_CMP_ACTION_PT_INSTANCE::sweep_timegroups + 0x10d
0x54a87: HDB_CMP_ACTION_PT_INSTANCE::close_pdb_and_clear_cache + 0x127
0x2cbb: HUT_UTIL::restore_cap_inst_from_pdb + 0xfb
0xa736: CSYN_EXPERT:: operator= + 0x89a6
0x45fe4: CSYN_ENV::restore_state + 0x104
0x2751: FSYN_ENV::restore_state + 0x31
0x11acb: CSYN_EXPERT:: operator= + 0xfd3b
0x6a1f: CSYN_EXPERT:: operator= + 0x4c8f
0x4d4b6: CSYN_EXPERT::run_single_algorithm + 0x296
0x4c340: CSYN_EXPERT::run_flow + 0xd0
0x4b891: CSYN_EXPERT::late_fsyn_flow + 0x291
0x48e5a: CSYN_EXPERT::do_physical_synthesis + 0x68a
0x5b888e: VPR_QI_FACADE::vpr_qi_fsyn_fus_init_chle_lib_api + 0xfd41e
0x2c9ad9: VPR_QI_FACADE::~VPR_QI_FACADE + 0xdad19
0x1c5cf9: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x1b05a9
0x1b80fd: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x1a29ad
0x19b275: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x185b25
0x1a2b8d: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x18d43d
0x1c5d5b: VPR_QI_FACADE::vpr_qi_get_start_and_end_progress_bar_perc_for_fsyn + 0x1b060b
0x1db717: VPR_QI_FACADE::vpr_qi_main + 0x27
0x2de91: fitapi_run_vpr + 0x71
0x46e18: FITCC_EXPERT::run_vpr + 0x138
0x48c0f: FITCC_EXPERT:: place_and_route + 0x14f
0x4aff1: FITCC_EXPERT::invoke_fitter + 0x711
0x4798: fcuda_execute + 0x1f8
0xbab9: fmain_start + 0x7f9
0x1525: Legacy_fitter_Init + 0x4b5
0x2618: Legacy_fitter_Init + 0x15a8
0x2168: Legacy_fitter_Init + 0x10f8
0xf8a6: TclInvokeStringCommand + 0xc6
0x112a8: TclEvalObjvInternal + 0x328
0x121b5: TclEvalEx + 0x8d5
0x12d48: TclEvalObjEx + 0x2d8
0x1abbd: Tcl_EvalObjCmd + 0xfd
0x56917: TclExecuteByteCode + 0xe47
0xa2376: TclObjInterpProcCore + 0x76
0x7c117: Tcl_FSEvalFileEx + 0x1d7
0x7a626: Tcl_EvalFile + 0x36
0xc1ff: qexe_ipc_progress_bar_name + 0x12bf
0x11dd6: qexe_get_command_line + 0x1556
0x150d5: qexe_run_tcl_option + 0x585
0x1e03d: qcu_run_tcl_option + 0xb8d
0x156ed: qexe_process_cmdline_arguments + 0x54d
0x15851: qexe_standard_main + 0xa1
0xa7f8: msg_exe_fini + 0x58
0xaf3c: msg_exe_fini + 0x79c
0x1f14: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0xb8bf: msg_exe_main + 0x8f
0x1841: BaseThreadInitThunk + 0x19
0x57508: RtlUserThreadStart + 0x20
End-trace
Quartus II 64-Bit Version 13.1.0 Build 162 10/23/2013 SJ Full Version
1 Reply
    Internal errors are usually deterministic and re-installing Quartus won't help. The fact that it occurs in the fitter doesn't help, because your code makes it through synthesis and generates something that is passed to the fitter, so there is nothing "wrong" with your HDL. What are the fitter messages around it? Maybe you can see what's occurring and maybe there's a way to get around it. For example, if Physical Synthesis is occurring, maybe you could turn it off. What happens if you try a different seed?
