11 years agoInternal errors are usually deterministic and re-installing Quartus won't help. The fact that it occurs in the fitter doesn't help, because your code makes it through synthesis and generates something that is passed to the fitter, so there is nothing "wrong" with your HDL. What are the fitter messages around it? Maybe you can see what's occurring and maybe there's a way to get around it. For example, if Physical Synthesis is occurring, maybe you could turn it off. What happens if you try a different seed?
