AVanB3
6 years agoQuartus II apparently doesn't automatically use the simulation testfile that was made for a 4 to 1 Mux and its already in the VHDL file put in In- and output declarations to simulate input data without manually presetting the in-and outputs first?
A complete VHDL file with added testbench file of a 4to1 Mux apparently doesn't run any simulation in Quartus II 13.x ? I do not know if I still have to config all in and outputs first manually. Or t...
sstrell
6 years agoWhat tool are you using for simulation? If it's ModelSim, the testbench should be a separate file, not included with the design itself.
If you're using the old built-in simulation tool of Quartus, you need a .vwf file for the testbench.
#iwork4intel
