BKB
2 years agoQuartus generated simulation script looks for VCS1 when VCS1 is not in the tool path provided
Hi, I am trying to run the example design simulation script generated by Quartus for DDR and I also tried to generate a simulation script for libraries from Quartus. I am using Quartus 22.3 and als...
ShengN_altera
2 years agoHi BB,
./vcs_setup.sh: line 254: ./simv: No such file or directory
This probably due to you didn't broadcast the env changes in the bash env. I believe you're using bash to run vcs_setup.sh. Can you type bash and then env to list all the env and provide the list here. Make sure to make changes to all the bash env. If still can't, try use vcsmx (/tools/synopsys/vcsmx/T-2022.06/linux) instead of vcs and see.
[Edited]: For the tool on my site, I first enter the bash mode then using arc shell vcs-vcsmx-lic,vcs/S-2021.09-SP1 to broadcast the bash env changes. I'm not sure how you broadcast the bash env changes.
Sheng
