BKB
2 years agoQuartus generated simulation script looks for VCS1 when VCS1 is not in the tool path provided
Hi, I am trying to run the example design simulation script generated by Quartus for DDR and I also tried to generate a simulation script for libraries from Quartus. I am using Quartus 22.3 and als...
ShengN_altera
2 years agoHi BB,
Check screenshot below, i specify the executable location path and it shows the simulation tool name of VCS S-2021.09-SP1. However, I can't find that tool name as well. But I successfully compile the library.
If you try compile the simulation library in GUI, any problem? If yes, then probably there's problem with the path ady.
Sheng
