MinexTO
2 years agoQuartus FPGA error TCL Operation load notstatic
I'm downloading modelsim and using it on intel quartus lite, but I'm unable to do so when I do it, I get error saying TCL Operation Load Notstatic. I was able to run this properly before my pc was re...
- 2 years ago
Based on the error message:
Error: Top level entity/module name for test bench not specified -- cannot continue NativeLink simulation
Have you specify the correct testbench module name in Assignments->settings->EDA tool options->Simulation->Native Link Settings->testbenches?
Sheng
ShengN_altera
2 years agoHi,
May be try uninstall totally and reinstall using QuartusLiteSetup installer. Make sure also to set the Tool Executable path in Tools -> Options -> EDA Tool Options
Sheng
- MinexTO2 years ago
I still have the same error ._.- MinexTO2 years ago
No, Also does the wun32olem appear automatically in the above method or we need to install separately (the modelsim)
Info: Start Nativelink Simulation processInfo: NativeLink has detected Verilog design -- Verilog simulation models will be used========= EDA Simulation Settings =====================Sim Mode : RTLFamily : max10Quartus root : c:/intelfpga_lite/23.1std/quartus/bin64/Quartus sim root : c:/intelfpga_lite/23.1std/quartus/eda/sim_libSimulation Tool : questa intel fpgaSimulation Language : verilogSimulation Mode : GUISim Output File :Sim SDF file :Sim dir : simulation\questa=======================================================Info: Starting NativeLink simulation with Questa Intel FPGA softwareSourced NativeLink script c:/intelfpga_lite/23.1std/quartus/common/tcl/internal/nativelink/modelsim.tclWarning: File Week2_run_msim_rtl_verilog.do already exists - backing up current file as Week2_run_msim_rtl_verilog.do.bak11Error: Top level entity/module name for test bench not specified -- cannot continue NativeLink simulationTCL OPERATION LOAD NOTSTATICError: NativeLink simulation flow was NOT successful================The following additional information is provided to help identify the cause of error while running nativelink scripts=================Nativelink TCL script failed with errorCode: NONENativelink TCL script failed with errorInfo: package "rdb21" isn't loaded staticallywhile executing"load "" rdb21 "invoked from within"if [ catch {eval gen_msim_script args_hash} msim_do_file_name] {error "$::errorCode" "$::errorInfo"} elseif {$script_mode == 0} {post_message..."(procedure "launch_sim" line 112)invoked from within"launch_sim launch_args_hash"("eval" body line 1)invoked from within"eval launch_sim launch_args_hash"invoked from within"if [ info exists ::errorCode ] {set savedCode $::errorCodeset savedInfo $::errorInfoerror $result $..."invoked from within"if [catch {eval launch_sim launch_args_hash} result ] {set status 1if [ info exists ::errorCode ] {set save..."(procedure "run_sim" line 74)invoked from within"run_sim run_sim_args_hash"invoked from within"if [ info exists ::errorCode ] {set savedCode $::errorCodeset savedInfo $::errorInfoerror "$result" $savedInfo ..."(procedure "run_eda_simulation_tool" line 334)invoked from within"run_eda_simulation_tool eda_opts_hash"
from .rpt file
