11 years agoQuartus doesn't detect source file change
I've a problem with quartus 13.1. When I have already successfully build my project there are green checkmarks in the Task Pane besides the Task e.g. Analysis & Synthesis, Fitter, Assembler. Now when I change some of my input sourcefiles (which are in the project). For example the toplevel vhdl file or regenerate the QSYS system. The green checkmarks are still present. Quartus did not see that the source files have changed. Even when I do a Project cleanup he doesn't detect the changes. For example the Assembler should not be green because there is not even a sof file anymore.... Does anybody has the same kind of problems? thanks tschinz
