Quartus does not accept ieee_proposed library.
Hi, I have a vhdl code that requiers Fixed point package. So How Can i compile this libarary into my quartus.
Error (10481): VHDL Use Clause error at LOAD.vhd(7): design library "ieee_proposed" does not contain primary unit "fixed_pkg"
- KennyT_altera
Are you using standard edition of Quartus Prime?
You may find the answer here
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd09062016_335.html?wapkw=ieee
- KennyT_altera
You may check your email for further details
- c7890
I think the files are exist in my ModelSim directory and when I import the package that I want, it works normally in modelSim. But the problem is when I past the same code in quartus it gives an error message.
The reason that I want to execute the code in Quartus because I want to visualize its RTL. Here is a screenshots
