GOMEZ_IT
2 years agoquartus disable automatic delay compensation
Hi, I was trying to simulate a simple circuit with Quartus, to use the Timing Analyzer for understand how the static timing analysis works. I was wandering if there is a way to disable the op...
- 2 years ago
So you're talking about the Optimize Hold Timing setting. Delay is added to meet hold timing at the expense of some setup slack. Assignments menu -> Settings -> Compiler Settings -> Advanced Fitter Settings.
ShengN_altera
2 years agoHi Luca,
That setting still can be found in Advanced Fitter Settings for Standard version.
