GOMEZ_IT
2 years agoquartus disable automatic delay compensation
Hi, I was trying to simulate a simple circuit with Quartus, to use the Timing Analyzer for understand how the static timing analysis works. I was wandering if there is a way to disable the op...
- 2 years ago
So you're talking about the Optimize Hold Timing setting. Delay is added to meet hold timing at the expense of some setup slack. Assignments menu -> Settings -> Compiler Settings -> Advanced Fitter Settings.
sstrell
2 years agoNot sure. Like I said, the setting was called Beneficial Skew. It's been gone for a while so that might be the case with Standard as well.
GOMEZ_IT
2 years agook. thank you very much for helping. I'll check the options tomorrow to see if I find anything similar.
my greetings,
Luca.
my greetings,
Luca.
