Jens's avatar
Jens
4 months ago
Quartus did not start
Since the switch to European Summer Time we cannot start Quartus Prime 2025 in Windows 11.
Error Message:
The application could not be started correctly (0xc0000142)
What could be the reason for that?
Jens
  • billmax's avatar
    billmax
    I should also ask - is anyone is running CyberArk in addition to Sophos?
  • billmax's avatar
    billmax
    Updated the Sophos endpoint to version FTS 2025.2.3.32.2-MR5 (This per our IT dept, I don't know exactly which products we're running). QuartusPro now runs OK, but we're still having an issue with some of the utilities such as quartus_sign.exe.  We still have an open ticket with Sophos.
  • billmax's avatar
    billmax
    For us it is currently resolved with a workaround of updating Sophos to
    • 2025.2.3.32.2-MR5 core
    • 2025.2.3.9.3-MR5 intercept
    and also adding exclusions to the Quartus bin64 executables folder. Specifically:
    • Add a Process Exclusion
    • Add a File/Folder Exclusion
    • Add an Exploit Mitigation Exclusion for the process and path
    The form of the exception entry is also sensitive, and works with (for example)
    D:\intelFPGA_pro\24.1\quartus\bin64\*.exe but not D:\intelFPGA_pro\24.1\quartus\bin64\*
    Sophos has not said whether the exceptions are permanent or whether they will work to resolve the underlying false detections related to Quartus.
    • Jens's avatar
      Jens
      Hi billmax,
      We tried applying this workaround to Quartus 25.3.1, but unfortunately it didn't work.
      Jens
      • billmax's avatar
        billmax
        The update has to be pushed to the client computer. If you're sure that's done the only thing I know to do is open your own support case with Sophos. You can reference case ID 03158718.
  • billmax's avatar
    billmax
    Different engineers in our group have different versions of Quartus installed. One of them has also successfully tested Pro version 25.3 after explicit Sophos exclusions were added. We have not had any issues with Quartus Prime or Lite. I will update the solution post above if I find that additional steps were needed beyond what's listed there.  Note that the exclusion is drive specific - if one user has installed on C:\ and another on D:\ that requires two explicit exclusions.
  • billmax's avatar
    billmax
    Below is a part of our discussion with Sophos - adding exclusions seems to be their position on cases like this.
    • Sophos continuously improves its detection capabilities to enhance protection against new and emerging threats. As part of these updates, detection logic may be strengthened or newly introduced. This can sometimes result in legitimate applications being flagged if their behavior matches known exploit techniques.
    • Additionally, if the application (such as Altera Quartus Prime Pro) performs actions that resemble exploit techniques or if certain components of the application are considered vulnerable, Sophos may begin monitoring or blocking those behaviors.
    • Some legitimate applications perform low-level operations (e.g., DLL loading behavior, memory manipulation, command execution, or dynamic code execution) that are similar to techniques used by malware.
    • In such cases, Sophos detects the behavior as a potential exploit, which may use advanced system-level operations as part of its normal functionality, even if the application itself is trusted. When you add an exploit or process exclusion Sophos stops monitoring or blocking those specific behaviors for that application. This prevents the Sophos endpoint agent from triggering alerts or blocking execution.
    • KennyT_altera's avatar
      KennyT_altera
      Thank you for your feedback. I will relay this to Altera and will get back to you with our position on this matter.
  • Jens's avatar
    Jens
    Hi Kenny,
    The administrator says there's nothing new in the workaround. He already did that two months ago (excluding the bin64 directory from Sophos scan).
    Unfortunately, I can't run any tests with Sophos myself, so we'll have to play “Chinese whispers” here :)
    Jens
