HituS
2 years agoQuartus cut paste not working
We are using Quartus 23.3.pro and copy paste function is not working with it. If I open another Quartus window with another design, cut and paste sometimes(*1) works, but only for single blocks, Not ...
RichardT_altera
2 years agoI assumed you are referring to the block diagram/schematic file(.bdf file). I tried and able to successfully cut and paste the block in the same/ different .bdf file.
Make sure when you try to cut the block, you need to click at a blank space first before paste the block.
OS info: Window 10
Quartus: Quartus Standard 23.1 Build 991.
I would recommend using HDL instead of schematics because as the design gets complicated, it becomes messy quickly.
Richard Tan
