HituS
2 years agoQuartus cut paste not working
We are using Quartus 23.3.pro and copy paste function is not working with it. If I open another Quartus window with another design, cut and paste sometimes(*1) works, but only for single blocks, Not ...
RichardT_altera
2 years agoAre you copying and pasting text from a text editor window, such as copying RTL code from one .v file to another? If so, I don't see any issue with copying and pasting multiple times.
Could you check whether this issue only occurs with Quartus software and does not impact other applications, for example, Notepad+?
You might need to restart your machine and see if the issue still persists.
More description of the issue and steps to duplicate it are needed as well. Also, which operating system does Quartus run on?
Richard Tan
