16 years ago
Quartus 9.1 crashes during Assembling
anyone got a problem with Quartus II 9.1 which crashes during assembling ? I get following report:
Internal Error: Sub-system: ASM, File: /quartus/comp/asm/asm_lab.cpp, Line: 1979
this->jiggle_signal_into_cache(signal)
Stack Trace:
0x1ea066: asm_assemble + 0x37dd (comp_asm)
0x1e9579: asm_assemble + 0x2cf0 (comp_asm)
0x1e8511: asm_assemble + 0x1c88 (comp_asm)
0x1e6ce9: asm_assemble + 0x460 (comp_asm)
0xd4e8: qexe_get_command_line + 0x7a8 (comp_qexe)
0xfd58: qexe_process_cmdline_arguments + 0x3f8 (comp_qexe)
0x25056: GEN_PROFILE_BINS::initialize + 0x216 (CCL_GEN)
0xfdee: qexe_standard_main + 0x4e (comp_qexe)
Best Regards
joel
    In my code, main program calls .vqm file generated by using synplify pro.
    Errors are:
    Internal Error: Sub-system: AMERGE, File: /quartus/atm/amerge/amerge_incr_tap.cpp, Line: 1034
    oterm
    Stack Trace:
    0x1f155: amerge_mini_merge + 0x1bd65 (atm_amerge)
    0x42b2: amerge_mini_merge + 0xec2 (atm_amerge)
    0x5d5b: amerge_mini_merge + 0x296b (atm_amerge)
    End-trace
    Quartus II Version 9.1 Build 222 10/21/2009 SJ Full Version
    Please give help. Thanks!
    ~Lily
    --- Quote Start ---
    Stack Trace:
    Best Regards
    joel
    --- Quote End ---
    I found some information from the hand book of Quartus II.Maybe this can help you.
    Problem:
    An internal error occurs when you use Incremental
    SignalTap II to tap an output port that is stuck at VCC or
    GND.
    File:
    pp, Line: 6076
    oterm
    Stack Trace:
    0x19F1C : amerge_mini_merge +
    0x16B3C (atm_amerge)
    End-trace
    Solution:
    Remove the tap node from your SignalTap II instance.
    -----------My Solution------------------
    This node does noting for solving my problem.My project is created by Quartus 9.1 and compiled by 9.0.I coped all my *.vhd file out and create a new project by 9.0 and then copied my vhdl file to the new directory and it worked.
    If that can help, I have the same problem, and I have find, the problem whith
    to many programs open in the PC, sò now I work whith 2 pc, one only for Quartus, and the other with pcb and sch, and now work perfect, I do not know whay, maybe the memory is to low, or there are somes interference inside the PC, but the important is NOW is OK
    regards
