17 years agoQuartus 7.2 lost signal in correct assignment
here is my code in brief:
I've problem with the red line. ==============================================
-- Serializer
-- sadid sahami
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
library altera;
use altera.altera_internal_syn.all;
entity Ser is
generic(
MTU : integer:=8192;
Counter_Width : integer:=14;
Label_Width : integer:=32;
SOF_len : integer:=8;
SOF :std_logic_vector(7 downto 0):=B"00001111"
port(
input_label : in std_logic_vector((Label_Width-1) downto 0);
Data_in : in std_logic_vector((MTU-1-32) downto 0); --serializer
Counter_in : in std_logic_vector((Counter_Width-1) downto 0);
clk : in std_logic;
ser_out : out std_logic;
dhs_flag : buffer std_logic;
d_flag : in std_logic;
c_flag : in std_logic;
l_flag : in std_logic
end entity Ser;
architecture Ser_arch of Ser is
signal label_mem : std_logic_vector((Label_Width-1) downto 0);
signal data_mem : std_logic_vector((MTU-1-32) downto 0);
signal counter_mem : std_logic_vector((Counter_Width-1) downto 0);
signal prtc_flag : std_logic; -- Packet ready to Combine
shared variable sr : unsigned((SOF_len+Label_Width+MTU+SOF_len-1) downto 0);
shared variable cnt : integer;
shared variable tmp : std_logic_vector((SOF_len+Label_Width+MTU+SOF_len-1) downto 0);
-- =====================function decleration=======================
-- crating function to convert the std_logic_vcetor to integer:
-- ===============function decleration==============================
-- a function to change unsigned value to std_Logic_vector
-- ================function decleration==============================
-- a function to change std_logic_vector to unsigned
begin
process(clk)
begin
prtc_flag<=dhs_flag and d_flag and c_flag and l_flag;
if (rising_edge(clk) and prtc_flag='1') then
-- load data for serializing:
label_mem <= input_label;
counter_mem <= Counter_in;
data_mem <= Data_in;
dhs_flag<='0';
end if;
cnt:=to_integer_stdvect(counter_mem+1);
tmp := SOF & label_mem & data_mem & SOF;
if(cnt/=0) then
ser_out <= tmp(0);
sr := to_unsigned_stdv(tmp);
sr := sr srl 1;
tmp := to_stdlogicvector_un(sr);
cnt := cnt-1;
end if;
if(cnt = 0) then
dhs_flag<='1';
end if;
end process;
end architecture Ser_arch;
Error (10344): VHDL expression error at Ser.vhd(141): expression has 8208 elements, but must have 8240 elements this is means that the label_mem dosn't apply to temp whay? I double check the code why? I've also use tmp as signal but nothing change or check the .qbf file for Ser's inst2's input : incoming_label has 32 bit length. by this code modification: tmp1 := SOF & Label_mem; tmp2 := data_mem & SOF; tmp := tmp1 & tmp2; this error appears: Error (10344): VHDL expression error at Ser.vhd(144): expression has 8168 elements, but must have 8200 elements this means 2 label and one SOF has been lost (32+32+8 I've also try direct numerical declaration but nothing change.... what about using concatenation....8240 vs 8202...
