Quartus 26.1: quartus_asm triggers quartus_pfg despite disabled generation flags
May I know what changes that you want to add?
I assume you are referring to my comment saying that I was not able to add bullet points to my post. I don't want to add any changes to my post. I simply wanted to mention that I had to change the formatting of my post removing all bullet points formations and have them simply formatted as a new-line each.
I would be, however, much more interested in any technical feedback regarding my observations of quartus_asm.
Thank you!
- Farabi_Altera3 months ago
Hello Axel,
Can you try using GUI. Just to check if the flow is working or not.
regards,
Farabi- axel193 months ago
Hi Farabi,
Thank you for your response. I forgot to mention it, but yes, I did try using the GUI and I got the same results.Best,
Axel- Farabi_Altera2 months ago
update from engineering:
1- .sof will be generated no matter what is set on this variable. This is expected behavior.
2- .rbf will be generated if user explicitly call quartus_pfg, no matter what is set on this variable. This is expected behavior.
regards,
Farabi
