axel19
3 months agoQuartus 26.1: quartus_asm triggers quartus_pfg despite disabled generation flags
Product: Quartus Prime Pro Edition Version: 26.1.0 Build 110 (03/26/2026) Component: Assembler (quartus_asm) / Programming File Generator (quartus_pfg) Environment: Linux Summary Running quartus...
axel19
3 months agoBy the way, the forum post formation is broken. It would allow me to add bullet points or code-blocks but when trying to publish it, it claimed that I was using forbidden HTML tags.
- KennyT_altera3 months ago
May I know what changes that you want to add?
- axel193 months ago
I assume you are referring to my comment saying that I was not able to add bullet points to my post. I don't want to add any changes to my post. I simply wanted to mention that I had to change the formatting of my post removing all bullet points formations and have them simply formatted as a new-line each.
I would be, however, much more interested in any technical feedback regarding my observations of quartus_asm.
Thank you!
- Farabi_Altera3 months ago
Hello Axel,
Can you try using GUI. Just to check if the flow is working or not.
regards,
Farabi
