Quartus 25.1.0 Not producing SOF File
- 1 year ago
Dear Richard,
Thank you so very much - this worked ! I assume this but will be fixed in the next release of Quartus ?
Bets regards
Shmuel
I will send you a Quartus INI to enable it.
Please check your email shortly.
Richard
Dear Richard,
Thank you so much I received the Quartus INI and then the compile produced a SOF. The problem is when I tried to program the SOF I got the following error messages (after approx. 32%) :-
Error(18950): Device has stopped receiving configuration data
Error(18948): Error message received from device: Bitstream error. (Subcode 0x0093, Info 0x00000003, Location 0x00000800)
Error(18948): Error message received from device: Device only accepts compatible bitstream due to export control.
Error(23925): Debug suggestion: Please check that the board is being programmed with a compatible bitstream.
Also I had to change the device that I was compiling to A5EC065BB32AE5SR0 for the Quartus Programmer to even start !
Best regards
Shmuel
- SDavi91 year ago
Any Updates ?
