Quartus 23 Lite
- 2 years ago
OK - my fault! I think the license I had was in the wrong directory.
My mistake, not signal tap but Triple Speed Ethernet for which I have a license file.
Warning (12188): Intel FPGA IP Evaluation Mode feature is turned on for the following cores
Warning (12190): "Triple-Speed Ethernet" will use the Intel FPGA IP Evaluation Mode feature
Warning (265072): Messages from megafunction that supports Intel FPGA IP Evaluation Mode feature
Warning (265073): Messages from megafunction that supports Intel FPGA IP Evaluation Mode feature TSE_MAC
Warning (265074): The Triple Speed Ethernet MegaCore MAC function will be disabled after time-out is reached
Warning (265069): Megafunction that supports Intel FPGA IP Evaluation Mode feature will stop functioning in 1 hour after device is programmed
I attach license file.
This didn't happen with Quartus 22.
