Quartus 23 Lite
- 2 years ago
OK - my fault! I think the license I had was in the wrong directory.
Signal Tap is included in all editions of Quartus.
Can you show the exact error messages you're getting? It could be that some other IP you are using is unlicensed.
- NGord2 years ago
My mistake, not signal tap but Triple Speed Ethernet for which I have a license file.
Warning (12188): Intel FPGA IP Evaluation Mode feature is turned on for the following cores
Warning (12190): "Triple-Speed Ethernet" will use the Intel FPGA IP Evaluation Mode feature
Warning (265072): Messages from megafunction that supports Intel FPGA IP Evaluation Mode feature
Warning (265073): Messages from megafunction that supports Intel FPGA IP Evaluation Mode feature TSE_MAC
Warning (265074): The Triple Speed Ethernet MegaCore MAC function will be disabled after time-out is reached
Warning (265069): Megafunction that supports Intel FPGA IP Evaluation Mode feature will stop functioning in 1 hour after device is programmed
I attach license file.
This didn't happen with Quartus 22.- NGord2 years ago
