Eric_Liu
1 year agoQuartus 23.4 often fail to compile
Hello everyone, I often encounter the following error when compiling with Quartus.: I can only keep trying to recompile, and sometimes I can succeed. May I ask what causes this? The software...
- 1 year ago
Hi ,
I copied the project to the root directory of a hard disk, and the probability of this error was greatly reduced. It might be caused by the fact that the path of the previous project was placed too deep.
Thanks for your concern!
ShengN_altera
1 year agoHi,
You're create revision based on other Quartus version, that's why the error appears. Please delete the revision and re-create the revision using current Quartus version.
Sheng
Eric_Liu
1 year agoThanks for your answer, Sheng,
Could you please tell me how to delete the revision? Do you mean I need to creat a new project?
I created current project base on Qsys system, It will cost a lot of efforts if I recreat a new one, How can I solve this issue just base on the current project? Thanks a lot!
