jdes
2 years agoQuartus 23.2 crashes on fitter : Internal Error: Sub-system: PTI
Hello, Quartus is repetitively crashing during the fitting stage with the following error : ``` Internal Error: Sub-system: PTI, File: /quartus/tsm/pti/pti_tdb_builder_nightfury_hssi.cpp, Line: ...
SyafieqS
2 years agoDid you able to verify this on 23.3?
Is the issue still persist?
jdes
2 years agoHello,
Yes, unfortunately the issue still persist with quartus 23.3.
You will find the error report attached to this post.
The tcl for generating the transceiver IP wasn't compatible so I has to update it.
For your testing purposes you can find the 23.3 compatible version at sha1 : 21f8f91e5e993bd2a69715e99478acdbcdf1c7e8.
( https://github.com/Essenceia/ethernet-physical-layer )
Best regards
