jdes
2 years agoQuartus 23.2 crashes on fitter : Internal Error: Sub-system: PTI
Hello, Quartus is repetitively crashing during the fitting stage with the following error : ``` Internal Error: Sub-system: PTI, File: /quartus/tsm/pti/pti_tdb_builder_nightfury_hssi.cpp, Line: ...
SyafieqS
2 years agoDo you mind to attach the design for me to replicate?
- jdes2 years ago
Thank you for getting back to me.The attached archive should contain all design files.
Alternatively the project is available on github :
https://github.com/Essenceia/ethernet-physical-layer
sha1 : 4b2dfac0fd23dcc6315a09f9e843b0a855e9ea9f
To reproduce my exact build flow which triggers this crash :
cd tcl
make place_PCS
This build flow will setup the quartus project, generate the IP's and launch the full flow ( `execute_flow -compile` ) , which will then fail during the fitter stage.
Additionally, I have confirmed the failure can also be reproduced when launching manually from quartus.
I will be happy to provide any additional files if required.
Best regards
