Quartus 21.1 devices troubles
Hi, I installed the 21.1, the last version that support MAX V devices.
When I make a new project I can't select the devices, it not appear any device. Then I try install the MAX V devices and I get the message of image 3 because the devices are installed but I can't use any device.
If anyone knows what I could do, I would appreciate your help.
Martin
- sstrell
Something's messed up in your installation. I'd just uninstall, make sure you have the correct .qdz file, and then reinstall.
- Nurina
Does above comment help?
Nurina
- MartinE
Hi Nurina and sstrell, I uninstall the complete version and try to install. This time I only install the program and install the qdz with the device installer, the result is the same, I can use the quartus but I can't select any FPGA/CPLD.
Martin
- sstrell
Bad installer perhaps? Try re-downloading. Not sure what else could be the problem. Try on a different computer?
- Nurina
Did you set up your license? Which OS are you using?
Nurina
- MartinE
Hi Nurina, I'm ussing windows 10 Pro version 22H2. I select the Connect to the Intel Self-Service Licensing Center in the Quartus init.
Martin
- Nurina
Are you meeting the minimum requirements:
Minimum Disk Space for Intel® FPGA Software
- Intel® Quartus® Prime Pro Edition Design Software (20 GB)
- Intel® Quartus® Prime Standard Edition Design Software (15 GB)
- Intel® Quartus® Prime Lite Edition Design Software (14 GB)
- Intel® FPGA Programming Software (3.3 GB)
- Intel® FPGA SDK for OpenCL™ (3 GB)
- Intel® SoC FPGA Embedded Development Suite (8 GB)
- Intel® Advanced Link Analyzer (5 GB)
If yes, maybe try Quartus 20.1std?
Nurina
- MartinE
Hi Nurina,
I installed the Quartus 20.1. With Quartus 20.1 te devices are listed.
So do you have any idea what might be happening with 21? Or should I use 20?
Martin
- Nurina
Hi Martin,
Usually this is caused by licensing issue. Would you like for me to look into it or you're fine with using 20.1std?
Nurina
- Nurina
Any updates?
