MartinE
3 years agoQuartus 21.1 devices troubles
Hi, I installed the 21.1, the last version that support MAX V devices. When I make a new project I can't select the devices, it not appear any device. Then I try install the MAX V devices and I get ...
Nurina
3 years agoHi Martin,
Usually this is caused by licensing issue. Would you like for me to look into it or you're fine with using 20.1std?
Nurina
