Quartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SG
I don't see the error that you are seeing.
Please kindly confirm whether it works by download the QAR design that you shared and run it in a new folder.
This will ensure that the design is able to duplicate the error.
Additionally, the top level entity 62702_krpi is missing.
Hi Richard,
Sorry, I am missing to check the altera community forum. looks like as it is failing to create hps IP it is not reflected in .qar file, could you please try to create an HPS IP core from your end and see if the errors I shared earlier are replicated.
Chandu sri
- RichardT_altera8 months ago
Pasting the error here for reference and tracking:
Warning: krpi_hps.arria10_hps_0: HPS model no longer supports simulation for HPS FPGA Bridges. Warning: krpi_hps.arria10_hps_0: This module has no ports or interfaces Info: Platform Designer Tip: Please Sync All System Infos before attempting to resolve the following error messages Error: krpi_hps.arria10_hps_0: Unsupported device 10AS057K2F40I1HG Error: krpi_hps: list element in quotes followed by ":" instead of space while executing "foreach {pad_id ball_name } $location_map { set pad_name "PAD_${pad_id}" set pad_to_ball_name($pad_name) $ball_name #send_message info " $pad_na..." (procedure "elab_io_interface_signals" line 36) invoked from within "elab_io_interface_signals $peripheral_name $mode_value peripheral_ports" (procedure "elab_FPGA_Peripheral_Signals" line 123) invoked from within "elab_FPGA_Peripheral_Signals $device_family" (procedure "elab" line 60) invoked from within "elab 1" (procedure "compose_logicalview" line 7) invoked from within "compose_logicalview" Error: krpi_hps.arria10_hps_0: "Counter for GPIO debouncer" (CONFIG_HPS_DIV_GPIO) 0 is out of range: 1-65535 Error: krpi_hps.arria10_hps_0: "Sugested peripherial PLL VCO frequency" (PERI_PLL_AUTO_VCO_FREQ) 0 is out of range: 320-3000
I do not see this error on my side. Could you confirm whether this error occurs during the Platform Designer Generate HDL process?
I’ve attached a simple design for you to test it out.
Richard Tan
