AEsqu
Contributor
6 years agoQuartus 20.1 crashes with VQM from synplify pro 2020.03
Quartus 20.1 crashes with VQM from synplify pro 2020.03 (old mapper, new Intel mapper fails at synplify side for another reason) Problem Details Error: Internal Error: Sub-system: CUT, File: /quar...
KhaiChein_Y_Intel
6 years agoHi,
It is difficult to investigate the root cause without the design. I understand that you cannot share the full design. Is it possible to provide a simple test case for issue replication?
KhaiY
- AEsqu6 years ago
Contributor
I could if the Intel crash report was a bit more precise,
it does not mention the instance/module that makes the crash.
Is it possible to enable an debugger log or so to figure out on which block of the VQM it fails?
