Quartus 13.1 License
Hi Phil,
for Cyclone III designs, you can use Quartus 13.1 Web Edition without a license for everything including Signaltap. Only licensed IP, e.g. PCI compiler isn't available without a respective license. Most IP is contained in IP Base suite bundled with Quartus subspription license. Means if you have a recent Quartus license, it also enables licensed Quartus 13.1 features.
PCI compiler is legacy IP, I'm not sure if respective license (e.g. 6AF7 0022, 32-bit Master/Target) is still contained in IP Base suite or must be purchased seperately.
Frank
It seems I am blocked from generating RBF files because I have the time-limited PCI feature in my design. From what I just read, it needs to be purchased separately.
Where can I purchase it? I attempted to run my build with a recently generated Quartus Prime evaluation license but that didn't work
- paveetirrasrie_Altera4 months ago
Hello Phil,
Good day to you.
Apologies for the delayed response. Kindly let me know if the issue persist?
Pavee
Hello Phil,
Good day to you.
Kindly let me know if you required further support on this matter?
Pavee
We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get the support from Altera experts.
Thank you.
