Quartus 12.0 License
Hello
Welcome to Intel forum. To narrow down this issue, can you please provide me the latest of the following?
1) Debug.log file
2) assembler report .asm.rpt file
3) Machine OS information
4) Output of “lmutil lmstat –a –c <port>@<address>” server and client
5) license.dat file
FYI, you can find debug.log file at LMTOOLS > path to the debug log file.
You can refer to this following YouTube on how to find debug log file ( min.2:55)
https://www.youtube.com/watch?v=llLaWatUbe8
And the asm.rpt.
The assembler report is located in <Project directory>/Output_files/<project_name>.asm.rpt.
You can also reply/attach your file in private message.
I had two license servers. 9006@elmslicna01 and [email protected].
The attached lmsta_elmslicna01.log file is from the first server which is still in operation.
The attached license.dat file was running by server [email protected] but this server has died.
The FEATURE we need is in line 143 of the license.dat file. It is a license from MORETHANIP.
We tried to clone it with a new server using the same MAC address but because the names of the Ethernet ports are different so we cannot run the license.dat in the new server.
I don't have a new dspv2_top.asm.rpt file because compile failed because the MorethanIP license is missing.
The attached dspv2_top.asm.rpt was generated when the server [email protected] was still running two years ago.
I wonder if you can generate the same license for us but for a new server host.
