14 years agoQuartus 11.0 Web the MegaWizard can not instanciate ALTLVDS_TX _RX functions
On Windows XP 32bit Pro I get "could not open the java virtual machine" error after clicking Next on Page 2a of the Megawizard. This happens consistently for the ALTLVDS_TX or _RX but the wizard works well for the ALTGX, ALTBUF and other functions.
The Java application launcher error "could not open the java virtual machine" happens consistantly when I start the MegaWizard Plug-in manager and attempt to create a new component or edit a previously created using the ALTLVDS_TX or _RX megafunctions. The Megawizard Plug-in works fine with many other Megafunctions including the ALTGX, ALTDQ ALTIOBUF to name a few. The error is the same if the Megawizard plug-in is run from the Quartus software or from the Windows Start->programs->... menu The error happens after clicking Next on page 2a of the MegaWizard Plug-in manager - it does not matter which type of output file is selected After reading about the problem - which seems commonplace - I experimented by killing all unnecessary programs, anti-virus, services to insure maximum RAM is available for the Java launcher and no software conflicts - all without success People are suggesting to add a -xmx<max_memory_size> to the command startup but other than in the Java console (which I tried) I do not know how to do that On the Linux version running on a VM CentOs 5.6 the Megawizard also fails consistently for the ALTLVDS_TX or _RX but the wizard works well for the ALTGX, ALTBUF and some other functions. Here the MegaWizard starts the launcher but crashes, the error messages are more detailed: [david@localhost ~]$ cd /opt/altera/quartus/bin/ [david@localhost bin]$ ./qmegawiz Error:Error in CNX file format. Error messages are listed in file /home/david/altera/txOutputSerializer.cnxerr. Can't create the custom megafunction variation file(s) The ....cnxerr file: ******************************************* ** CNX File Error Log ** ******************************************* Line 0: "DEVICE_FAMILY_MAX3000A 90115425O1313202012J" No valid wizard signature (generation mode ) found Has anyone encountered these problems? Any solutions? Altera SR says: Quartus 32 bit versions have known problems particulaarly with the megawizard - solution: use the 64 bit versions
